SLC 500 CPU Fault
tranebwc
Aug 2022
Juarez
hello
at work we have a machine controlled with an SLC 500 fixed, model 1747-l30c at fault, i plan to migrate to a micrologix controller.
I'm trying to connect with the UIC, but i cannot seem to find it on RsLinx, i've worked with micrologix, controllogix and 5/03s & 5/04s, but i can't seem to configure this controller to appear on RsLinx.
Can someone point me in the right direction?
Will i need to use the PIC?
Any help will be much appreciated
Helo alan_505
i changed the baud rate on the UIC with the gateway software, still no luck, i cannot see the slc on Rslinx. Only the USB and OK leds are turned on on the UIC.
i tested the UIC on a 5/03 and i can see it on Rslinx.
this SLC500 can't seem to communicate.
Interesting old post..
Ken Roach
December 18th, 2006, 08:17 PM
I dug out a bunch of old SLC-500 gear tonight to figure this out for myself.
The 1747-UIC evidently only works with Fixed I/O SLC-500 controllers (the old 1747-L20, -L30, -L40) when they are on active DH485 networks.
http://www.plctalk.net/qanda/uploads/UIC_FixedSLC.GIF
One modern way to provide the extra DH485 node when you want to go online with a fixed SLC is to use a 1761-NET-AIC and a small MicroLogix 1000 set for default protocol = DH485. You can connect the MicroLogix and the 1747-UIC to the two RS-232 ports on the 1761-NET-AIC, then connect the DH485 trunk port of the 1761-NET-AIC to the DH485 network port of the Fixed SLC-500 controller.
Systems that have Fixed SLC-500 controllers connected to PanelViews, DTAMs, or other SLC controllers using 1747-AIC isolators will work when you plug the 1747-UIC into the 1747-AIC's "Peripheral" port.
Maybe Ken will check in on this one or someone else.
I used up my last new Allen-Bradley SLC 5/04 controller. Does anyone have info on a good reliable place to get a new one for a decent price, or...
525
Hello everyone, I got called down to a plant to service a powdered metal press. It has an SLC 500 5/02 CPU that was faulted for the code 0002h...
1,802
I recently inherited some 5/04 CPUs and a single 5/02 CPU that I need to pull the programs from. The 5/04 CPUs didn't pose any problems. I...
3,051
Hello, first of all, I want to say thanks to everyone who is seeing this post. I have a problem with an SLC 500 5/05 processor. I need to download...
2,794
Good Morning , How do you replace the battery on a SLC 500 CPU without loosing the program , since you need to remove the CPU , and the...
12,056
