mark@snappy
We have a machine which uses a an a SLC150 to control functions. It has a fresh battery to back-up the memory, however anytime equipment power gets shut down, the "red" cpu fault LED goes on
and plc drops out of the run mode.
Right now PLC gets back into run mode by hooking up lap-top
and putting PLC back into run mode.
Is there a eprom setting that needs to get changed and some additional lines entered into our machine control ladder to stop
the PLC from faulting out?
I am sure there is a straight forward solution to this, but at the present time I have not been able to solve this issue.
Please advise.
Thank you for your attention, understading and your time.
Respectfully,
mark@snappy
Please advise.
Respectfully,
mark@snappy
