How to change baud rate on SLC150 (PCIS software)
Dec 2010
Toronto
Hello Gentlemen (and Ladies),
I have a SLC150 I am playing with. It's baud rate is 9600. Easy to establish comm with it using a 1745-PCC. Recently I was at a job where they also have a slc150, and I could not communicate with the customer's unit until I set the 'Configuration (F7)' in PCIS to 2400.
My question is: How do I set the SLC150 baud rate? how does one SLC150 have a baud rate of 9600 and another 2400? where is this configured in the PLC? I looked though the manual and looked at all the PCIS options and do not see a 'set baud rate' option. Yet two different SLC150 units have completely different baud rate that is not set in the code (as far as my limited understanding allows me to understand).
Do you know the answer?
Best regards,
Mike
I have a job using 1100. I need to change the baud rate with programming. Customer want to change on the fly without a computer. I don't see an...
21
4,557
Hello, I am using CPU226 I have downloaded Logic with 9.6Kbps Baud rate.It running ok.To increase Transmission speed I have to use baud...
1,940
Hello all, I am trying to connect to an OP17 panel to perform a download of the updated program. However, I cannot seem to change the baud rate...
3,569
I have two identical machines running similar HMI projects, the only difference is one is done in FactoryTalk View Version 10 and the other is...
154
Hoping someone can give me some guidance or confirmation of what I need to do. We have a FactoryTalk SE program that I need to change the IP...
102
