1747-L542 Power Problem.
jC.
Jul 2010
Australia
26
Ok, so I have a 1747-L542 Series C here...I put it in the rack (1746-A4, power it up and the lights come on the processor and the power supply for about 1 second then turn off. I've tried different power supplys, racks so I'm sure it's the processor that's causing the problem. Any Ideas?
Cheers.
Can't help you with your problem but I admire your patience.
You might try removing any modules and see what happens. If that works put one in at a time.
See PDF below for some trouble help
Good Morning , I have a SLC 500 rack with a 1747-L542 CPU and 2 DeviceNet scanner cards. I am having a terrible time going online with this...
4,376
Does anyone know what a 358H processor fault code is.
1,928
So I recently purchased a 10 slot rack with a SLC 5/04 1747-L542 cpu. I want to hook up an HMI screen using the RS 232 port but I dont know how...
1,873
Hello everyone, I am having issues with a 5/04, it started a few weeks ago, if the CPU is powered off then it has issues rebooting, I have found...
6,622
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
99
