1756-CN2R Different Series
epicnote
Feb 2011
Malaysia
45
Hi all,
I have to replace a faulty module of 1756-CN2R Series B for IMCS System. The system has 2 redundant rack which I believe for software redundant since there is no 1756-RM2 module available. The faulty module located in secondary rack. However, I plan to replace the faulty module with 1756-CN2R Series C (the only spare module available at site) which is different series with the existing one.
My question:
Do I need to re-schedule the ControlNet network once I replaced the faulty module with 1756-CN2R Series C because my client don't want to stop their production?
Thanks in advance
It probably can't hurt to try; set up the module for the correct Node Number using the rotary switches, and see if it accepts the Keeper and schedule information from the rest of the system.
"Software Redundancy" is very, very tricky. A-B has never recommended it, and only supports it in some very limited circumstances.
If you have a critical system that uses some kind of home-built pseudo-reundancy mechanism, I very strongly recommend that you get the OEM to consult before attempting to modify it.
Hi Ken, thanks for your reply. Mean no need to re-schedule the ControlNet network? Just need to set the node number rotary switch as per old module right?
The principle is that the ControlNet modules will receive the current configuration and schedule from the "Keeper" node.
As long as you set the Node Number correctly, the worst thing that's likely to happen is that the secondary chassis doesn't receive that data and go into operation.
Do you know what version of controller firmware and 1756-CN2R/B firmware is already running ?
It's possible that the existing controller and 1756-CN2R will not connect to the new one because of firmware compatibility or electronic keying issues.
The existing firmware is 1756-CN2R Series B F/W: 20.009. In the logic, for 1756-CN2R Electronic Keying: Compatible Keying
Hi Team, If I change the 1756-CN2R RPI value in online will it goes out from the Schedule. because we have experienced the same situation...
624
can anyone help me to programmatically get data from a 1756-CNB (R) and 1756-CN2 (R) modules using CIP message? info such as: max_connection...
2,024
I received this in a PM yesterday from a new member, TLEMCEN, who has not posted to the Public Forum yet. With respect to our new member, and...
2,592
Guys, I'm configuring a redundancy system (network, CPU, power supply), i used to use 1756-CNBR at the remote chassis. I'm not sure what is the...
11,409
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
77
