1756-IF16H Unused Channels
Mstachura
Jun 2014
calgary
We are using a 1756-IF16H that has a few spare channels. The channels that are SPARE are indicating a channel fault. Is there a way that I can clear this fault from happening via the configuration of the individual channels? Thank you :)
Setup the unused channels for 0-20 mA and place a jumper across the input terminals. I don't know if you can disable alarms on a per channel basis on that particular module.
I have1756-16F & 1756-IF16H analog input module connected to my contrologics 5572 controller. there is only single sensor connected few days ago &...
3,291
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
74
373
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
163
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
146
