Paul351W
I'm running some 1756-IF4X..... fast analog I/O cards and I was updating firmware on some ethernet cards and got in the groove and updated one of my series A fast I/O cards from v1.4 to v3.5, which I gather makes it a series B card.
After I made the firmware change I started getting a 16#0204 communication error on the card. I tried flashing back to v1.4, but after I downloaded the firmware I found on the Rockwell website that you cannot flash a B series (3.5) to an A series (1.4). However, it will allow me to flash 1.4 onto the card, but it errors out when it tries to check if the flash completed successfully.
I've tried changing the Program configuration to a B series and it still won't communicate. If I try to check the module status tab in the properties dialog box it times out and says the module was not found, but I can see the module in RSLinx.
