1756-l55
sandy5020
May 2012
vadodara
112
I have a CPU with 1756-L55, Which version of RSlogix5000 is to be used as I have version 20 and its not supporting. I tried to install version16 and some installation error is showing. I have only version 19 to 30
Regards
Sandy
Is it running a machine? Do you have an archive file (*.acd)?
If you have a project file, you can open it in notepad and look at the first part of it which is a version history. The last entry in the list is the last time the file was saved. That will tell you the last version of RSLogix 5000 that was used.
If it's running a machine and you don't have an *.acd file, you can right-click on the PLC in RSLinx and pick "Device Properties". That will tell you the firmware revision. Once you have that version of software installed, you can upload the program. You will end up with tag names and code but no descriptions or comments.
If it's not currently running a machine and you need to program it...as has been said, you'll need v16 of RSLogix 5000. As Harrstein said, I would suggest a Windows 7 VM for v16 and WinXP for older versions. I've had v15 or so working ok in a Win7 environment, but v13 and older will not work with anything newer than WinXP. In my experience, you'll be able to install/run the software in Windows 7 but going online will not work. If the PLC is running a machine and isn't at v16, you'll need to install whatever version it's running to make sure you have a good copy of the program. I would then strongly suggest getting it to v16. We can help with that procedure if you haven't done it before. Best option, of course, is to move to an -L8xE series, but good luck getting your hands on one.
Is it using the serial port? If so...that's another complication with migrating it but that's the "next" problem and not today's.
Hii,
Thanks for the advices!! I have managed to find the Rslogix V12-20.01 versions in a full DVD copy. but I tried to install it on a windows7 and windowsXP machines both of them are giving errors. On windows7 after installing there is an error showing fatal error and windows xp (32bit) not able to install it.
Tomorrow I will check with rslinx the firmware version!!
Sandy
Hi, I want to exchange data between two L55 PLCs using ENBT PLC1 is the main PLC and consist of 1756- CNB, L55 CPU and ENBT. Five remote I/O racks...
1,031
Hi, Anyone can help to get the FW16 for 1756-L55 as the CPU OK indication is flashing red as I have a new CPU and inserted a memory module. While...
1,711
Hi, I just bought a new control logix 1756-L55 from a supplier in UK. The Red indication is showing stable and as per the manual its showing CPU...
1,825
Hi all, Any experience of the above? Happened 3 times now in 1.5 months. Processor is about 10 years old, software major revision is 19...
5,549
I still have three applications using the 1756- L55 Processors on some new clients and in the need copy of Firmware ControlLogix 5555 1756-L55...
4,244
