1756-L8# PLCs - SIZE instruction, using alias as source, rev 16 vs 30
dscish
Jun 2019
UK
17
I've found an interesting issue on some code I've converted from rev 16 to rev 30. The original code has a SIZE instruction with an alias used as the source, the alias being linked to the first element of an array. It seems that in revision 16 this worked ie. returned the size of the aliased array (I can see that as it's passed to a variable in the same rung), but in rev 30 the SIZE instruction returns a 0, ie. it doesn't "translate" the alias and this doesn't see that the source is an array at all.
Any ideas if something got changed in the way SIZE is implemented going from rev 16 to 30? Imho it's bad practice to use an alias in this case, I'd much prefer using the original name of the array (it's first element), but the assumption is to make as little changes as possible to avoid re-testing (clearly in this case it needs to be modified).
Regards,
T.
Can anyone screen shot an example message block In a Control Logix PLC to communicate to a Micrologix 1400. I tried this the other day and ended...
3,141
Hi, I have two identical RsLogix 5000, 1756-L61 PLCs connected to a Ethernet hub. Slot[0] 1756-L61 Brain Slo2[1] 1756-ENBT/A ENet Slot[2]...
4,865
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
84
404
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
183
