1756-OB8 vs. 1756-OB32
Oct 2016
Philadelphia, Pa
20
Hello Group
Hope everyone is well
I've used the 1756-OB32 in the past, but now need to use the 1756-OB8 due to space limitations. I've reviewed the Rockwell literature, and it seems that the OB8 provides the exact same functionality as the OB32, but with fewer points.
However, I'd like to get some other thoughts from fellow PLC users if they can confirm that
Let me know as soon as you can
Many thanks in advance for any help that you can provide
Hello Group
You will not gain any "space" by substituting an OB8 for an OB32, both modules are the same physical size.....
The functionality of both modules is exactly the same. Physically they are same size as well. Good part about OB8 is that whoever will do the wiring will have plenty space.
We have a policy in company not to use 32 channels card, unless client will want exactly those, due to wiring space. 32 cores of .75 looks ridiculous and if you want to replace one core once it has already been wired it is a nightmare.
If we use the 32 channel cards, we now buy the premade cables from Rockwell.
Not cheap, but looks a lot better, and no scrabbling for the electricians to pull wires out of the loom to check and trace connections up to the card....
I prefer to use the 16 point input cards. They have decent density and you can get the 18 #18AWG wires inside and close the door.
Same goes for the 1769 cards. Even though the 32 point cards are twice as wide, they don't have twice the room for wire, so its impossible to close to the door on the front of the card unless you use really small wire.
... now need to use the 1756-OB8 due to space limitations.
What do you mean with "space limitations"?
You're right. Price is something to be considered:
1756-OB8 --> ~ $500
1756-OB16E --> ~ $600
1756-OB16I --> ~ $800
1756-OB32 --> ~ $750
Hi everybody, I have with me the following: 1. 1756-L73S controller + 55L7SP safety partner 2. 1756-ENBT 3. 1756-DNB 3a. 1791DS-IB8XOB8 3b...
2,235
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
71
367
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
161
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
145
