1756 -OF4 Output No Higher Than 5.9 ma
Rob S.
Sep 2008
Maryland
739
I am working on a new project and I am just benchtesting the design and components. I have a ControlLogix with a 1756-OF4 Analog output card. I am operating a valve and the output will not go any higher than 5.9 ma. I also hook up a Current / Voltage Calibrator to the output and it goes no higher than 5.9 ma. What would be the reason that would not go any higher. It seems like it is all 4 outputs. I know I have to have something setup wrong. Any ideas?
Thanks in advance,
maybe, Double check the Limits Tab for the channel(s) in question. I've had that issue in the past they defaulted to a low value and clamped there?
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
98
416
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
183
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
159
Hi, Is it possible to for an RIO with Flex 5000 series module, e.g. 5094-AEN2TR, to communicate with an 1756-L72E processor.
103
