1756-of8i
PLCUU
Aug 2022
Arizona
Im migrating a 140 ACO 130 00 analog output module to a 1756-of8i , the thing is that i have connected output without returns (on shneider), is the same connection possible on 1756-of8i?
Thanks before hand, im actually kind of new to this.:p
No. The 140ACO13000 is a current sinking output module requiring an external loop excitation power supply. The 1756-OF8I is a current sourcing output module that gets it's loop excitation power from the chassis backplane. You need to wire it according to the wiring diagram on Page 188 of the manual.
Hi Guys, For Allen-Bradley 1756-OF8 module, the channel status word has a bit for open wire detection "ChxOpenWire". I checked for the 1756-OF8I...
2,365
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
77
376
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
164
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
148
