dalporto
Edit: title is wrong: 1756. Sorry.
Hello.
Is there a way or an instruction to retrieve the CPU IP Address from the program (and assign each part to an INT)? Not sure if I'm clear: I want the PLC to read its own IP address.
I found it can be done for an onboard Ethernet Module, but is it possible to get the CPU address?
With Schneider it's quite easy, but with Rockwell I'm not even sure this can be done.
Thanks.
Hello.
Thanks.
