1768-eweb
markymark31
Mar 2004
Corby, Northants
60
Hi Guys,
Is anyone able to take a look at the attached and tell me where I am going wrong ?
This is my first go at socket communication so in this test program is a routine called "Mettler_Socket_Comms".
I think I need to ......
Create a Socket
Accept a connetion (to listen to the port)
Read some data when it is sent to me
Whilst online to the processor i can manually trigger each of these steps and using the web page of the EWEB I can monitor what's going on.
The Mettler_CreateSocket seems to work and returns an instance. But I can't get the Mettler_AcceptConnection message to work. It returns an error 70 EWOULDBLOCK "Operation would block" according to the manual but I don't understand the error.
The Mettler_AcceptConnectionTimeout waits for 60 second of inactivity before closing the socket, and if i change SockAcceptTimeout from 100 ms to 60000 ms I can get the socket to show as "Listen" on the web page for 60 seconds before dropping out with the above error. But I can't get the connection to accept and return with an instance.
Until this bit is sorted I can't move on to the READ !
Any help will be appreciated ....
Mark.
Can you enable Webpage Log, run your program until it is faulted and post log here.
Also it would be helpful to post wireshark traces for the same event
There is no way to say what is wrong without logs
Edit:
Actually since you still have only 3 rungs and long way to go, I recommend you to copy code from technote 33672 - this is complete server and you will only need to change a port number
Does this module have the capabilities to broadcast plc status over a closed wireless network? I'm wanting to connect it to a wireless router...
2,437
Hi I'm trying to communicate with 1768 eweb with Socket Interface. the manual says that i must initialize a MSG instruction, and select Create...
3,715
Hi I must write a custom webpage, from wich a user can save a csv file that contains the controller tags and their values. I use a 1768-eweb...
2,667
Hello Friends I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP. Now, I am trying to...
286
Apparently, they are not compatible and i was hoping there was a work around.
692
