1769-ASCII Setup Help
lam2363
Aug 2013
Virginia
17
All,
I have a 1769-L24ER-QBFC1B processor with a 1769-ASCII card that I am trying to get working on the bench. I have a standard serial cable hooked up from Channel 0 of the ASCII card to the COM1 port of my computer. All I'm trying to do at this point is a simple bare-bones hello world program with a terminal (termite or putty) so that I can verify my setup and understand how it works before I try to implement it on the plant floor. I have the card set up in alternating mode and am using the pre-canned program found starting on page 35 of the user manual(1769-um012) .This is my first time using the ASCII card I am familiar with the CompactLogix processors and the RSLogix Suite. Any insight you can give would be greatly appreciated.
Thanks,
Lucas
Thanks for the reply Garry, I had the wrong cable and have now made my own per the thread you sent. I can now transmit from the PLC to the terminal just fine but I cannot receive anything form the terminal. I have also tried making the cable match the spec in the user manual with no change (tying 1, 4, and 6 together) in the communication behavior. I'm sure its something simple that I am missing but I can't quite figure it out. I don't suppose you have anything else I can try.
Thanks,
Lucas
This is maddening. I'm developing a new application where a 1769-L32E with a 1769-ASCII module is communicating with a Tegam micro-ohmmeter...
1,589
so, Micrologix 1500. 1769-ASCii module. Bringing data in over the Channel 0 serial port. Setup is attached below. As is a snippet of the code...
1,639
I tried searching but either there aren't any answers out there for my Google-fu isn't up to snuff. My customer has a laptop with Labview set up...
1,557
Working with a customer who wants to do some ASCII handshaking between the PLC (a 1769-L24ER) and Labview on a laptop. I can send data from the...
1,866
Hello Everyone, I am looking for some help on this dreaded 1769-Ascii module. I have been doing a lot of digging on this module in the forum...
2,466
