1769-IT6 configuration
radarwolfe
May 2005
Trying to add a 1769-IT6 thermocouple module to a 1769-L20 compactlogix. 1769-IT6 module has an OK green light when powered up, but a blinking I/O not responding light on. Fault code is (Code 16 #118, module configure rejected. Format error.) Card is a Series A, Revision 5. Options in the program are for Series A, revision 1.1 - 1.15. Is there any way the revision numbers are the problem and if so, is there any way to configure around this fault?
All, I am having an odd parameter issue with an IT6 module that I cant figure out. My set up: L33ER, OB16, OA16, IQ16, IQ16, PB4, IT6, IF8 on...
12,471
Hi everyone. New to RSLogix5000 and learning as much as I can. I'm much more familiar with Omron. Is it required I select "scaled for...
1,844
Anyone know a fix for this? 1769-IT6, 2 modules both have same problem. Setup for K tc, 1x engineering units data, degrees F, 60Hz filter...
4,258
hello, im having trouble using the raw data in my program for a temperature. this is the first time ive used the IT6 card I have 6 thermocouples...
2,607
hey all, Having a bit of an issue setting up a thermocouple card with the compact logix, i searched the forum and found this post...
2,922
