Hello,
We have been having persistent communication failures on our network and recently upgraded to the 36ERM to support additional CIP connections.
Currently I am logging a comm failure with a GSV for my first remote I/O module status, logging when it isn't a value of 4 which means running. When I detect a comm failure, the status will change to a 3 and comms will be down for an extended period of time. Communications will rectify themselves 30-90 seconds later but by that time my remote I/O has failed and a number of other issues are triggered.
I have not been able to determine 100% if the issue is network hardware, server connection software polling data or another PLC configuration issue. We replace all control panel ethernet switches except our main Meraki router and switch with no change in the problem. Troubleshot cables, replaced a few to make sure, even pull new runs to the Remote I/O with shielded Cat6.
What I am needing to know, is there some specific GSV values I can get from the controller that will tell me the number if CIP connections are active at the moment of failure or possibly any other items that you may suggest logging.
Any other suggestions/questions welcome. We have 5 racks of remote I/O with a wide range of discrete and analogs.
