1769SM2 communication
That's not a whole lot to go on, but Google is remarkable.
Is this the AC20 single-loop controller you are referring to?
http://www.supersystems.com/single_loop_controllers.html
The Set Point values are in the Modbus reference manual for the AC20:
http://www.supersystems.com/AC20_COMMS.PDF
Page 18 says that the Main Set Point is Modbus address 138.
What exact parameter do you want to read as the "PV" ? The AC20 Modbus user manual says on page 37 that it can run with the Carbon Potential, Dew Point, or Sensor Output (millivolts) as the primary control variable.
The more detail you put into your request the better data you can get from the Forum.
107
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
41
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
37
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
213
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
46
