1771-OAD and 1771-OAD C
ToddM
Oct 2004
Cascade Va.
106
Hi Folks....I ran across an interesting problem today and wondered if anyone else has seen this before. About a week or so ago we had an output go bad on a 1771-OAD output card, all we have in stock are 1771-OAD revC cards. So I put one in place and everything is cool, or so I thought. Today a solinoid valve connected to the same card would not work unless you pulled the swing arm out and back in again. So I pulled the card next to it which was a 1771-OAD and put it in that position and vice versa. I then noticed that the 1771-OAD revC in the other slot would not drive any solinoid vales connected to it. It seemed to work with any other device but a solinoid valve. I went out to the "bone yard" and found a 1771-OAD, put it in and everythings right with the world. I searched the AB knowledge base but came up empty.
Any theorys or ideas?
Thanks and later...Todd
The difference between OAD and OAD C you see on the picture is the front connector.
"C" you see stands for a wiring arm that was shipped from the factory with this card. No differenece between here.
But difference may be between series of the card - different series, different hardware.
In any case - do not get cards from the boneyard, get a new card from A-B distributor.
Cont_conn
What I call the "boneyard" is our shop stock {Cards from different plants that have closed and we got their "bones"} So it's good stuff ,it's just not chargeable through the supply room. All our supply room stock comes from the A-B distributor.
Preface: Kinda long, so I made section titles Intro: I just want to see if anyone here has seen anything similar. A PLC5-40 series C enhanced...
372
Have three 1771 OAD B output cards that the active light does not come on. Stand alone rack..no remote racks Tried new cards...same Tried new...
2,189
Hello everyone, I am looking for tips and tricks how to upload a program from 1771-DMC CoProcessor. A client has a PLC-5/40B with CoPro Main...
3,742
We have installed a new 1771-OAD output card in slot 6 of a 16slot rack. The active light on the card will not come on . There is power to the...
2,300
Hello, I have using AC 110V Output module's for a PLC/5 system. Now I have Optocoupler's connected to this Output's. Problem is that when a...
2,599
