stallone
Good day all,
i have a 1794-aent that went faulty today.
The module status light is flashing red and the network light is solid red.
If i go into rslogix 5000 v19, i can see the yellow warning on the io module in the tree.
I right click to see port configuration and try reset module but i get an error to say code16#0005 connection request error bad class. or i get cip error in communication request. Module mismatch.
I have check the ip address and even reset module to factory settings and assigned ip again using bootp then disabled bootp. but still the error.
I plugged laptop directly to the module and did bootp then rslinx could see it and the status of the module said ok.
The minute i plug the module back into the networkm then the module status flashes red again.
I also get incorrect module cip object does not exist.
I can ping the module and i can see it in rslinx but its got the red x over it. and in rslogix 5000 it just keeps saying faulted.
Any thoughts or info would be greatly appreciated.
