How to change IP address in 1794-AENT module
Right-click on the module in the RSLinx Classic "RSWho" browse and select "Configure Module".
If the module is a Series B module with a three-digit numeric selector switch and the value is set to between 1 and 254, then the module address is 192.168.1.xxx. Change the numeric selector switch to change the address within this subnet, or set the switch to 999 to make the 1794-AENT use a software-selected IP address (as above).
This information is in the Installation Instructions pamphlet that is enclosed in the module's packing box, and is also available online:
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1794-in082_-en-p.pdf
If you do not know or cannot determine the IP address of a 1794-AENT Series A, re-post and forum members can guide you through that procedure.
I have a Red Lion G09 scanning 8 Invertek P2 VFDs via modbus RTU - I've setup necessary comms and tags and all works well. I have a 'Settings'...
1,882
It might seem like a stupid question but please let me elaborate. I had a PLC that already had some IP address on it which I needed to change. My...
5,837
Hi everyone, how can I change IP to a beckhoff BK9105? I tried via web broser but nothing! For the moment I have set the IP via bootp / dhcp...
2,095
Morning All, So I have a PLC-5/30 with a 1785-ENET module that I am needing to change the IP address on. I know very little about PLC's but have...
1,869
How do I change the IP address of a EN2TR module in a remote rack in a running PLC in Studio5000? When viewing the module properties while online...
2,581
