gabidamir
Hi everyone
I have an issue regarding the integration of a 1797-IBN16 Flex IO module on a network with a 1769-L33ER CPU
they will communicate thru a 1794-AENTR Ethernet adapter.
I have added the Ethernet module to the network but my problem is that when I try to add the Flex module on the chassis of the Ethernet adapter I can only add 1734 family modules.
Should I use a generic module like 1734-MOdule and then configure that one to fit my Flex IO.
If so is there someone that can guide me a bit towards that. I have tried to do that but I cannot find the figures for Assembly instance Input/Output/Configuration
Any help will be very highly appreciated.
Thank you
Thank you
