2 Siemens Comfort HMI's Master Slave
cottagewood
Oct 2005
Kent
179
I'm putting together a system with a Redundant S7-1500 CPU and 2 Comfort HMI’s on an MRP ring.
The HMI’s will be doing the same job and only one person should be on the site operating them.
Is it possible to set them up as a master and slave?
The things I would like to achieve:
1.Logging into one HMI would automatically log the other one off
2.If a user is created at runtime on one HMI, it would also be available on the second HMI
3.The event logs/audit trail would match, but in the event of a failure of one HMI the 2nd one can still display the log
1. Is there any particular reason why both can't be masters all time?
I assume that connection is profinet as you are connecting them to MRP ring.
The easiest way to do most of the required features would be to set it up where one HMI displays the other with Sm@rtserver/Sm@rtclient. Only one can be operated at a time, and the logs would all be in one place. However, that wouldn't give you failover capability. It simply allows HMI 2 to more or less be a remote display for HMI 1. The logs/users/etc only exist on HMI 1.
The HMIs are single station HMIs, not a client/server SCADA setup or a redundant system. Changes rolled out to 1 do not get automatically deployed to 2, and users/logs/etc, do not automatically get shared.
1) would be possible via scripting, I think. I've seen systems do things to control which HMI is in control of a machine/system/etc. You can log off via system function or script, and you can control whether objects are enabled via animation.
2) I think there is a system function you can use to export the user admin from the HMI. With luck, maybe you could do it to a shared network drive, then import from the other side? You could also use SIMATIC Logon to centralize the user administration to some PC somewhere, or active directory.
3) I think the audit logs can be exported to a network drive as well. They wouldn't MATCH, but you could export both of them, to protect against an HMI going down.
No reason, as long as both are not logged in together, as mk42 says, that could be done with script,
For the adding a user, the worst case would be they have to add one on both HMI's,
I could really do with a common Audit trail though
Hello great friends. Please help me....what is the easiest way I can RESET a Siemens TP700 COMFORT HMI Touch panel, to its Default...
1,239
Hi, I have been successfully sending emails from a Siemens Comfort HMI (TP1200), configured with a "Gmail" address via VB Script. The VB...
2,281
Hello Experts, Hopefully I have an easy to answer question. I am remotely connected to a S7-1500 with TIA Portal V16 & a Comfort TP1200...
842
Does anyone know if it's possible to display the alarm Log with just the on State of an Alarm and not the Off state.
997
I need to confirm that the can we convert the KTP1200 Basic PN to TP1200 Comfort HMI. I am using TIA Ver 14 and it shows the Device change option...
2,239
