24v DC Input for TM221CE16R from Sensor
QasimFSH
Apr 2018
Adelaide
142
Hi ALl,
I am using TM221CE16R for my plant automation. This controller of schneider only accepts 24v dc as input. Less than 5v is a definite low, and more than 15v is considered as a high state. The issue is that I am planing to use some sensors for water level detection, but I am sure non can provide output of 24v. What can be done? I can use the sensors as a switch to 24v supply to the PLC, but this is my last resort.
Any suggestions?
Thanks.
A lot of point level detection is simple switches, which switch an applied voltage.
What level detectors can't handle 24Vdc?
I'm not sure the best way to do this. I've got an old GE plc with only 120V relay outputs. I'm replacing a UV light component with an LED...
1,886
Hi , I have a faulty input card on a gem 80 plc I have versions of the replacement card Does anyone know the difference between a 9513 -...
1,079
Hey, I am using a CompactLogix L32E, and trying to control my input module(1769-IQ16 (which is 24VDC sink/source)), using a Panel view 700 HMI. I...
2,240
Hey guys were having difficulties with a flow meter that takes 24VDC PSU but sends 4-20ma output as we verified. The Compact Logix analog module...
17
10,724
Hi, I am using AB 1766L32BXB PLC to connect convyer kit(which is 24vdc supported)"...
5,875
