312IFM (6ES7 312-5AC02-0AB0) problem
dimigav
Jun 2009
Thessaloniki
34
I try to work with an 312IFM CPU module.
I make a simple FC with I124.0 and Q124.0 to check the CPU.
Everything seems OK (compiling & downloading) but the program did not run.
I put the I124.0 to L+ and no Q124.0 activation.
I saw something like module test function is enabled.
Can you help me please??
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
183
Hi, I am using CM_CAN in my project in Transparent mode. The CAN modules needs transmit 240 message definitions each of 8 bytes, 168 message...
79
Hello: Just posted a similar inquiry with regards to Rockwell HART master. Trying to figure out whether the Siemens offering is better. I need to...
4,808
I've been fighting a problem with this 8 channel analog input card mentioned in the title. I believe it's something I'm doing in the wiring but...
1,722
Hi guys, Some pointers needed: Having PC with WIN7 pro X64 and Amsamotion clone of 6ES7 972-0CB20-0XA0 cable and need to backup VIPA cpu...
3,136
