321 ethernet module with 90-30 cpu 311?
unsunghippie
Jun 2006
Deer Park, WI
51
I have 3 GE CPU311's that I would like to tie into Cimplicity PE. I know it is possible via serial connection with SNP multidrop, but will these cpu's support a CMM321? I have heard varying stories, some involving additional modules, firmware rev. level issues, etc. Anyway, is it possible, and what are the requirements?
You will need an IC693CPU311-U (Ver. 5.03) or later, order 44A731233 to update older versions. You could also look into the IC200SET001 Ethernet to Serial adaptor.
Thank You
Thanks much. You guys are great in the GE forum, too. I took a look at the IC200set001, and it looks like the way I would prefer to go, due to limited slots on the backplane. It says it requires rev 8.2 or greater in the CPU311. I assume the upgrade kit mentioned is at least that? I am also curious as to where you find the manuals you quote so often. I haven't been able to find them on the GE websites.
Is anyone familiar with the AAIU to RJ45 adapters for CMM321 modules? These modules are now obsolete but I had to add some ethernet modules to a...
1,655
I'll keep this as brief as possible, but it is a long story. I've been programming 90-30's since the late 90's. Haven't used them much lately but...
4,785
Hello guys, I have an issue about maximum cable length calculation of a digital input on Siemens SM321 card. by calculation and according to...
2,919
So I found out that the CMM321-EE does not support modbus tcp. So I guess I am now trying to figure out how to communicate to a GE 9030 rack thru...
2,743
Hello! I'd like to know if someone can help me. I have a GeFanuc 90-30 with a CMM-EF module installed. The problem is that I need to communicate...
2,041
