3rd Party Ethernet Protocol using ControlLogix
sanger
Nov 2005
Toronto
172
We need a ControlLogix processor to send and receive data from a 3rd party device using Ethernet. Basically we need to open a TCP connection, transmit a block of bytes, receive a block of bytes, and then close the connection. We have an existing Step-7 processor doing this using the Simatic TCON, TSEND, TRCV, and TDISC functions but I need to determine a way to perform the same function with A-B.
May not be possible with 1754-ENBT
I've noted in reading some of the messages in this forum that Raw Ethernet Sockets may not be possible with the 1754-ENBT module we are using and that this may only be possible with the 1754-EWEB module.
Can anyone confirm or deny this.
You are correct with this.
What is the end device?
1756-EWEB / 1768-EWEB Open socket interface specifically developed to address applications like this
I would start with User Manual ENET-UM527 and technotes:
48879, 32962, 33672. Some technotes require Techconnect login, so make sure your KB profile has support number
I can't seem to find an answer in Rockwell's site or here. I am curious if CCW can connect to 3rd party devices via E-I/P like other brands and...
3,619
Hi, First time poster, long time reader. I've got a mass flow controller device for controlling the flow of gas. It has a flowmeter and an...
278
Should it be possible to upload hardware and software with TIA from a controller that has 3rd party profinet I/O (Muir) Impact67? I have only...
1,109
Hi everyone, Is it possible to position with third-party servo motors using PF 753 or PF 755 AC drives? I know torque and speed control are...
5,143
I have an ACT350 weigh scale transmitter from Mettler Toledo and am trying to import their sample code and tags into my project. On the website...
1,100
