5069-L320ER Shows in RS Linx but not FactoryTalk Linx
SandwichMagic
Jun 2015
Central California
96
Hey everyone,
Trying to connect to a 5069-L320ER compact logix over USB for the first time. RS Linx Classic can see the controller just fine, but when I try to set a path, Who Active doesn't see the USB connected controller. Using the FactoryTalk Linx browser doesn't help. Any suggestions would be appreciated.
I would suggest you make sure your USB hardware conforms to USB 3.0. In my experience USB 2.0 does not work well, especially with 5069-xx devices. I use to work with no problems with an old L16ER on one particular PC, and when tried to use a 5069-xx that we bought, it would not work properly with that PC.
Hey, Just as an update, This was the first PLC I was trying to connect to on a new computer, I just needed to configure the shortcut using FactoryTalk Administration Console, It started showing up after that. Lots of moving parts with FactoryTalk I am learning of.
Hello everyone, For my new project I want to integrate a Staübli Robot with AB PLC. I don't know how to get started with it. How can I integrate...
2,165
A project using the above landed on my desk. Attached are several OB16 cards. With any output turned off, a multi-meter still shows 24v to GND...
1,339
Hi All I have a problem with communication betwin 5069-L320ER Firmware 28.011 PLC from Allen Bradley and In Touch DASABCIP 5.0 driver. In this...
1,346
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
115
Hi everyone, Kind of new at this, so we recently upgraded our 1769-l32e to the newer 5069-L320erm, i converted the file over and Verify the...
409
