842E-M Encoders dropping out
ASF
Jun 2012
Australia
3,921
Hi all,
I'm currently designing a project involving about a dozen Ethernet/IP encoders to be connected to a Control Logix. No motion control stuff, just basic position feedback on a slow-moving shuttle conveyor. At this site, another integrator on a different project used six Allen-Bradley 842E-M encoders, but after a few months of operation, ended up wiring their power via a NC output relay to enable them to cycle power, because as they explain, they kept dropping off the network and needing a power cycle to reconnect. They recommended I don't use that type for my project for that reason. My thinking is that surely if that were an inherent problem with the encoder, AB wouldn't be selling as many of them as they do. Surely, it must be something specific to their application?
Who here has used these encoders? If you have, how many have you used and how often (if ever) have you seen this type of issue?
And in case I do have to go down the path of a different model, who can recommend a good Ethernet/IP encoder for connection to a Control Logix?
I used 3 of these on our forming lines in a few plants for many years. I never had a communication issue. The areas are well designed to mitigate noise and even used shielded Ethernet cables to the encoders.
Heavy wash downs daily with hot water and continuous use. Never a comm issue.
Also, I didn't have a managed switch in this application. Simply a conventional gigabit switch.
I eventually swapped them out for conventional 1024 PPR encoders and High Speed Counters, but not because of comm issues.
Thanks. Yeah, I'm fairly convinced there's a human at the root of their problem, not the encoders. Good to hear that others aren't experiencing the same!
Hello, I am working on a project that is converting a 4-20mA device to an absolute encoder. The device is measuring a jack screw that lifts a...
4,346
Dears, i am trying to change the series of encoder from A to B, but the program do not has this option (Rslogix5000, 20.06 the old encoder was...
216
All, I've been lurking for quite a long while, and ran into something I could use some help with. We have an application that previously had an...
2,425
I am working with a Allen Bradley Absolute Controller (842E-SIP5BA). I was wondering if anyone has any experience with them. Pros/Cons? Has...
2,122
Hi, I have configured a project with the following hardware. 5069-L30ERM 842E-CM-S Absolute Encoder. Stratix 2500 1783-LMS5 (Is this suitable?)...
26
5,774
