842e encoders
whuff
Mar 2005
Toledo, OH
17
Hello, I am working on a project that is converting a 4-20mA device to an absolute encoder. The device is measuring a jack screw that lifts a table up and down. The 4-20 a electronic yo-yo that did not hold up. The encoder is mount right to the worm drive. Right now I get 0.00833" of linear travel per turn. The encoders we are using are the A-B 842e to controllogix L-63 firmware 19.0. I have communication. Where I am getting in trouble is converting the position data to linear data. We set the table position to 1" and move it up. I want to take the encoder data and translate it to start at the 1" and go negative as the position number gets smaller and display this data on the screen. I have down scaling before but having a hard time getting this one to convert. Any advice would be appreciated. Thank you.
I have never used ethernet encoders, but you can try to set up a motion axis and configure your linear displacement based on encoder data. I have never done it, all my experience is based on motion modules with incremental encoder hardwired to the modules.
That is my usually way to do this too. I am trying to wrap my head around converting counts to a linear scale through a revolving device and the brain is just not working. Thanks for the advice.
Hi all, I'm currently designing a project involving about a dozen Ethernet/IP encoders to be connected to a Control Logix. No motion control...
2,180
Dears, i am trying to change the series of encoder from A to B, but the program do not has this option (Rslogix5000, 20.06 the old encoder was...
216
All, I've been lurking for quite a long while, and ran into something I could use some help with. We have an application that previously had an...
2,427
I am working with a Allen Bradley Absolute Controller (842E-SIP5BA). I was wondering if anyone has any experience with them. Pros/Cons? Has...
2,123
Hi, I have configured a project with the following hardware. 5069-L30ERM 842E-CM-S Absolute Encoder. Stratix 2500 1783-LMS5 (Is this suitable?)...
26
5,777
