984-680 Modicon Processor Password Retreval
Jabbercocky
Oct 2008
Whitehaven
I need to work on a Modicon PLC but some twit has pasword protected it and I am locked out! Does anyone know how to retreive a password from the processor or any other way to get into the system?
Any help most appreciated!:geek:
OZEE said:
We don't discuss password hacking here. Contact your Modicon tech support.
I never mentioned Hacking anything.
What about reseting the system and re-installing the software. would this work? Or am I snookered without the password?
What Modicon software are you using?
Wondering whether its a security issue with the PLC or with the software. I don't recall the 984 having a password in the PLC itself, then again I try to remember as little as possible about 984s. But if its the PLC then clearing and reloading should work, but if its a feature of the software, for example PLCWorkshop for Modicon password protects access to functions in the software such as the ability to save or download, not just the PLC program itself, in which case you would be screwed if you erased the PLC program.
Alaric is correct in one respect.... there's certainly no way to password protect access (when using Modsoft anyway)...but the -680 CPU had a MEMORY PROTECT keyswitch - are you sure it's in the OFF position?
Our company has two aluminum MIG welding machines made by PDSI in Dayton, Ohio in 1988. These machines have Gould-Modicon PLC Controllers, model...
19
10,782
I'm new to Modicon. We're looking at an application where the client has a Modicon 984/685 series CPU and both comms ports are in use. We need...
5,515
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
225
Hi I have a modicon 984 with proworx 32 that is scaling an analog input, and I need to adjust the scaling. I have new analog input values and %...
1,729
Hi, I am trying to get a machine started that was moved from one location to another. It has a Modicon 984-A131 PLC. I have Schneider Electric...
1,024
