A-b Cables
Jnelson
Apr 2002
Philadelphia, PA
198
The company i work for recently bought two used machines one with a slc 5\01 and one with a slc 5\02.
Since i am not farmilar with ab plc's, I figured you guys would be the ones to help.
I purchased rs logix to do the programming and troubleshooting, but i am not sure what cables i need to connect to these processors.
My allen bradley book is older than i am so it is of no help.
If anyone can help me with part numbers i would appreciate it.
Also if any other information is needed about processor or laptop, i will respond asap.
Thanks,
John
Surprisingly enough, you can connect to the A-B 9-pin ports using a standard 9-pin null modem cable.
Pinouts on the CH0 DF1 port are 2 RXD, 3 TXD, 5 GND, 8 CTS, 7 RTS
Actually the 5/01 and 5/02 don't have a ch0 port on them (only on the 5/03 and higher). You need a 1747-PIC to connect directly to these or an AIC(s) to network them on a DH-485.
GRS
The 5\02 processor is running a hmi on a local computer and is using a pic box.The 5\01 does not have this though.
So what you are saying is that all i need to connect to either one of these is a pic and the cables from the pic to the plc and the pic to the pc.
The current pic is pn 1747-pic.
So, does anyone know the cable part numbers?
Thanks,
John
The 1747-PIC ships with the cable to connect to the SLC (1747-C10 I believe) and includes a ribbon cable with a 25 pin connector for the pc. All you would need (possibly) is an adapter if your pc has a 9 pin serial port.
yes you do need a 1747-pic(generally for notebooks) or a dh-485 linc coupler(adapter interface module 1747-aic, used to link to data highway). the pic is quite expensive unless you pic one up from ebay....
Thanks alot, that's all i needed to know for now.
This is a new adventure and i am sure i'll be running into more problems.
Thanks,
John
If using a laptop save yourself a LOT of headaches, get the 1784-PCMK (pcmcia) card. The 1747-PIC was a good device but is outdated in alot of ways and computer technology is changing and the PIC is being left out of it in some ways.
They say the PIC is expensive, well the PCMK is way more so BUT it elinminates problems connecting to a variety of AB products, just have to obtain the appropriate cable.
http://www.ab.com/manuals/cn/netssp064ause.pdf
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
197
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
113
Hi all, i have several Proface GT2400 terminals and i need to get the software and interface cables and i have several questions. I am assuming...
166
Hi all, I wonder what's the best type of cable to use for RS-485 2 wire + GND That is, Data+, Data- & GND I know that Belden 9841 (not...
1,089
Kindly, we connected electrical power, 3x380 vac, between a supply station and an electric cabinet, away 180 meters. The calculation software...
865
