A-b Cpu-5/01
johnny ayala
Oct 2002
bloomington .Ca
HI I WAS TRYING TO UP LOAD A PROGRAM FROM A-B 5/01 CPU
BUT IT GAVE ME A DECOMPILER ERROR CAN SOME ONE GIVE ME ANY
POINTERS HOW TO UP LOAD THE PROGRAM.
THANK YOU IN ADVANCE
Over the 12-year history of the SLC-500 controllers there have been a few instances where status table or data table conditions were allowed by some compilers (especially in the days where there were 3rd party compilers) but were not allowed by later, more strict compilers. When a newer (or sometimes Buggy) compiler attempts to *de*compile that "illegal" instruction or memory construct, a decompiler error results. Usually there's an error number associated with it.
The crucial thing for you to know, Johnny, is what revision of what software package are you trying to use to upload the program from the SLC-5/01 ?
If you search the Rockwell Knowledgebase for the keyword "decompiler" you will find a handful of notes that apply to specific revisions of specific editors. In almost every case, the fix is to get a newer editor or use an older editor to change the condition that causes the decompiler error.
http://support.rockwellautomation.com/knowledgebase/
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
170
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
76
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
70
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
117
