A Big and Unique Project
Apr 2002
No income tax, no capital gains tax. Freedom!
8,391
Last year at about this time I was invited to go to the National Airport Pavement Test Facility to help out with their test system. Usually our controllers are used to test landing gear, blades, flaps etc but in this case the purpose was to test the runway. The big A380s are going to put a lot of stress on the runways so the FAA wants to simulate runway wear to determine the rate of wear and how to make better runways.
The previous system consisted of a Mitsubishi Q PLC that talked to many smaller Mitsubishi PLCs that controlled each of the 10 actuators. There are 5 per side and two wheel per actuator. The first system did not control very well for a number of reasons. RMC75s were chosen to replace the smaller Mitsubishi PLCs. The motion controller has a position feed back for controlling the up and down motion of the wheel and a pressure sensor on each side of the piston to calculate a differential force across the piston and the offset can be changed so a net force takes into account the weight of the wheels.
The first day or two was spent by Ryan Rutter and me training each other. I trained Ryan on the motion controller and Ryan trained me on what the machine had to do and its basic operation.
The first challenge was easy. We got the Profibus working between the PLCs and motion controllers quickly. We also got the tuning for the force to work accurately under static conditions.
Problems started to occur when we tried to control pressure under dynamic conditions.
Someone had put a 3Hz filter in the feedback path. The feedback was an analog voltage for pressure. I said that will not do because you really end up controlling the filter and not the actual force. When the 3Hz filter was removed the feedback was extremely noisy. I left and came back a few months later after all the wiring was redone to reduce the noise.
The next hurdle was controlling the force as wheels went up and down over the ruts in the runway. No matter how high we turned up the gains the wheels would not track the target force and if we turned up the gains too high the actuator would oscillate. Not good. The FFA PLC engineer was concerned but I told him that it would be 'fun' and by the time we got done with this it would be a project to talk about. I was confident.
During the static force tests I noticed that the force increased by about 18000 lbf for every 0.1 inches actuator was pushed down. This relation ship wasn't that accurate but there is not point in sweating details if the general approach doesn't work. The ratio of force to position depends on temperature, the tire pressure and how much surface area the tire has in contact with the runway. My plan was to map the elevation of the runway. If I know the elevation of the runway at each point along it I can move the tire up and down in position control so the wheels are always compressed the same amount and therefore maintain a steady force on the runway. The runway test second is up to 300 ft long. I built an array in the motion controller for 601 readings so there was one every 6 inches. The controller can do a cubic interpolation between the points to compute a position and velocity. In the article there is a formula that shows the the flow entering or leaving the cylinder must be equal to the velocity times the area of the piston if the pressure is to remain constant.
We then rolled the tires over the runway slowly enough so the force PID would control the force accurately enough. The actuator positions were recorded every 6 inches and put into the array. The array was used to make a big cam table or spline that the actuators could follow as a function of the tests machine's position along the runway. This improved the response a lot. It was kind of like a feed forward or disturbance rejection because now the controller can predict the position of the actuator to achieve a force rather than to wait for a very compliant tire to push on the actuator.
As noted above, the ratio of 18000 lbf to 0.1 inches was a good estimate but not always accurate. There was still need for the force control. The force control PID was modified. Instead of outputting a control signal directly to the hydraulic valve it generated a position offset for the position PID that was following the elevation spline. This helped to correct for errors in our assumption that the force was proportional to how far the actuator was pushed down.
The idea worked great BUT there was yet another problem. As each wheel came down to hit the runway it lifted the WHOLE machine up a little and this meant that the wheels that are already in contact had to push down a little farther to maintain the same force. This meant that our tables needed yet another offset but we didn't know how much it should be.
The answer was to get laser to measure the distance from the frame of the machine to the runway. The laser can detect how far the machine is being lifted up as the next set of wheel come down. It could also map the runway elevation much more accurately than rolling the wheels over it. This was a big improvement. Ryan Rutter, control engineer, implemented this on his own. By this time he knew how to program the motion controllers.
So, this project uses cascaded control with an inner position loop and outer force loop. It uses splines to predict how far the actuator should be extend down to generate a force and all of this is geared to the motion of the machine as it travels up and down the test runway. Each of the wheels had to have a separate offset into the spline table. The synchronization was done over Profibus.
I was at the NAPTF for two one week stretches. The first week was have training and just getting the basics set up. It was the second week where the cascaded loops and splines were implemented.
http://www.airporttech.tc.faa.gov/naptf/
http://www.controleng.com/single-ar...c-controls-for-runway-testing/e17b8b3882.html
The Nation Airport Pavement Test Machine is a one of a kind. The US tax payer funds the testing and shares the test data with the whole world so that safer runways can be made. Think of the mess if Chicago, Heath Row or the Atlanta airports had to shut down a runway for maintainance for months at a time. The runways have sensors buried 20 inches below the surface to measure stress and strain. What is interesting is that the weight that pushes down on the center of the runway actually deforms the runway. The edges of the runway are actually rise up as the middle is pushed down. This happens even though the runways at 20+ inches thick. One more thing. The actual landing is not that bad on the runway since most of the weight is still supported by the wings. The runways are stressed the most when they are warm or hot and the plane is rolling slowly.
The article got delayed because unnecessary people in the FAA got furloughed last summer for a couple of weeks. That included Ryan Rutter, the engineer that is doing most of the control work. I know we get our money's worth from his efforts. The FAA has their own version of this article for their PR purposes.
Very interesting, thanks for sharing that Peter.
I never thought about it that way before but now that you mention it, it makes absolute sense.
That test vehicle looks like it might be too light to simulate a large aircraft. Does it have some ballast that isn't visible in the photographs or some sort of mechanism to hold it down on the tracks?
The machine is heavy enough. I asked the same question. The part the drives the wheels along the rail road tracks on the edges looks very heavy. I was told that as heavy as the test machine is the wheels can still lift the machine off the rail road tracks with the hydraulic actuators. We had to be careful not to do this but most of the time we were only moving one actuator at a time.
I am still amazed at how the runway deforms so much.
That is very interesting article Peter and thanks for sharing it with us.
One thing I didn't know that runways had stress sensors below the surface of the runways and I knew that they temperature sensors for checking the surface temp.
Outstanding article Peter. Your write up is the perfect mix of detail and summary so as not to overwhelm the non-genius readers like me, but it still shares details about the problems that were overcome and the results. $167,000,000 annual savings is over a hundred times more money than I ever saved a company with one project. And taxpayer dollars at that...
Thanks,
Paul
Great article Peter. I had a chance to vist Ryan and this facility last year it is very impressive, and Ryan is a class act. One question, did you have to take the "bus" in everyday or did you get a pass to drive in yourself?
Yes, Ryan does so much by himself without much guidance or help from all those other engineers/PhDs that monitor or process the data.
That was a pain in the a$$.
The first time there I could get a pass and drive in. The second time there I had to leave my car at the gate. Ryan would meet me at the gate when they opened. I had to get a badge and walk through the air port screening just like I was getting on a plane. Then I would hop into Ryan's vehicle. The hanger is separate from the Hughes Center, the main facility. I never went to the main building.
That's why I was asking, when I went I had to do the airport screening and then wait for a shuttle bus to take me to the hanger. I understand the need for security and I'm not complaining, I just chuckled when I read you were there for two -1 week strecthes I could see that getting old!
Hello all My manager was nice enough to provide us with these nice big screens. Yet bootp is as small as it is on my lap to. Is there any...
1,993
So, I ran into a motor and transformer someone was trying to get started today. Motor = 1HP, Transformer = 750VA With the transformer tapped...
3,881
Haven't run into this before. imported routine, but this one tag is not cooperating. Hoping I could get some quick help before i come completely...
1,549
Does anyone know of a 17" touchscreen that works properly with a RevPi Core 3 and Codesys? I tried a Viewsonic TD1711 which said it worked with...
1,367
Kindly, do you know another brand which makes "power shielded big cables" similar to the below ones? Power cable sold by the meter type...
1,384
