a little help
sheryl86_ann
Jul 2008
laguna
142
Hi! I was given new task and this is my first time anyway. Can anyone show me a sample ladder program (if available) involving servo motors? PLC- (FX3U-48MT). Do programming with servo motors a complex way? What points should I consider with? like timing? pulsing? is this all digital signals?
thank you.
sheryl
Sir Mickey:
Thank you for the site. The PLC is Mitsubhishi using GX developer. May I ask if have you tried servo programming before? Do you have any sample program?
Most of the servo applications that I work with, the servo has the program and the PLC does only digital I/O with the servo... ((start/stop/goto/speed)) these are all digital outputs to the servo from the PLC and digital inputs to the PLC from the servo are ((moving/healthy/not healthy/at speed/at postitionX/etc))
The servos are faster and better to use then the PLC for control, just use the PLC to control/interface with the rest of the machine.
Now if you are talking just an inverter... then the PLC is the way to go.
I have several machines that don't have a PLC only servos that have I/O's
I have several Mitsubishi programs that use servos, you can send me a PM or email and I will send you one.
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
268
I am trying to use pylogix to write to a string array ID_Data_Table_Name. In the array there are 200 possible entries. For...
4,051
Hey guys, I have a client that has a v-notch chlorinator that doesn't run off a 4-20mA loop, it instead has two discrete inputs that drive the...
1,892
Hey all. I need some guidance here. This is something I came across today when a Ref guy noticed that the HMI isn't displaying the correct time...
1,468
i am a beginner plc programmer and have some confusion, a little help would be appreciated . why do we use a normally close contact when we are...
3,189
