ELake20
I'm attempting to calculate flow of nitrogen gas. I have a fixed volume but due to the discharge pressure and temperature will be changing. I've started with pV=nRT, here are the values I came up with for that.
p= pressure of gas, starting at 1000psi converted to atmostphere (atm) 68.04596
V= volume of gas, which is 23 cubic feet converted to liters 651.2875
n is what I'm solving for, which with my current parameters works out to 1870.69 moles
R= gas constant, which is .082057. I've converted my values to ATM, Liters & Kelvin for temperature due to this constant.
T = absolute temperature, 60 degrees converted to kelvin 288.7056.
Solving for n: (p*V)/(R*T)
I feel confident in the ideal gas equation, but when it comes to calculating density I'm lost.
The formulas I'm using for determining density of the gas are: mass = moles * molecular weight so mass = PV(MW)/RT
density = mass/volume so D=PV(MW)/RTV
My goal is to develop this to calculate the CFM of nitrogen through a pipe. I have a high response thermocouple mounted in the flow stream to detect the temperature change and will be plotting the values in excel during the discharge.
Once I have the density I'm that much closer to getting there. Am I atleast on the right track??
