a little question
vidi0816
Sep 2006
Salatiga
18
I always trouble to make rotary encoder with H21A1 or H21A3, that optocoupler always shutdown which i didn't know. how to make a good rotary encoder with H21A* series ?
Can you tell me where i can see example projects or please tell me how to make it good. I need it to analyze my PLCs projects.Thanks
Cheers,
Adi
Indonesia
When i check with osciloscope, the signal respon is work, when the detector closed , the signal down to zero, when open the signal rise up 12 volts. But when i connect it to my PLC, the signal going down to zero and never change when closed or open detector and the input led on my PLC still off.
Hi, I need to compress 3000 ft^3 of a syngas(synthetic gas) made up mostly of hydrogen, carbon dioxide and a little methane. I cannot seem to...
2,523
I used the recipe system in WInCC Flexible. I made a CSV by using export I make changes in the csv I used import When I do...
3,967
I need to regulate something in this way: How is this in math and how van I write it in stl ? Thanks in Forward.
3,546
I’m currently a student of Communication systems, majoring Multimedia and Design in The Netherlands. My first education was Technical Production...
2,642
hello, its me again>> i had been cracking my skull figuring out y the outlet valve is related by f1, f2 and f6 while the rest of the state is...
4,476
