A problem with SIMATIC S7-300, CPU 314 - 6ES73141AG130AB0
Gromit
Jun 2006
119
Hello.
This is the last order number for the SIMATIC S7-300, CPU 314: 6ES73141AG130AB0
CPU WITH MPI INTERFACE,
INTEGRATED 24V DC POWER SUPPLY,
96 KBYTE WORKING MEMORY,
MICRO MEMORY CARD NECESSARY.
The problem is that Step7 V5.3 does not recognises that CPU and requires a 2 MB MMC in order to update the PLC firmware.
I don't need to buy so large MMC. What can I do: updates, hotfixes, upgrading to Step7 V5.4 2006?
Regards
Try to update the HW catalog...
In Hardware > Options > Install HW Updates
Maybe there's an update for CPU314, you'll need...
Did you tried to install hardware updates? It's located in HW Config -> Options.
It's not clear, did you tried to download to PLC or to create project with this CPU only?
There is no firmaware update for this model of CPU314, it's the newest CPU314. You can download HW catalog update from Siemens and then you can find CPU in your Step7 catalog. You don't need memmory card with capacity of 2MB, but this CPU (like other new S7-300's) requires MMC for operation, you cannot use this CPU without MMC.
Actually,
To update the firmware, a MMC with at least 2MB capacity is required. This is only needed for the operating system update, afterwards you can put the smaller MMC back in for normal operation. I have a 2MB S7-300 MMC and a 4MB S7-400 Memory Module with my USB prommer I use solely for upgrading firmware.
This is a link to the Siemens instructions for updating firmware on a S7-314 CPU:
http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&nodeid0=10805159&csquery0=UPDATE%20FIRMWARE&caller=view&lang=en&siteid=cseus&aktprim=0&extranet=standard&objid=10805161&DataKey=10805161&treeLang=en
Best regards,
Chris
HW catalog update file
Hello,
where can I find the HW-catalog update-file for the CPU 6ES73141AG130AB0.
I have follow software:
1° Step7 lite V3.0 with SP1
2° Step7 V5.2 with SP2
Hi Guys, I am facing a problem with my Siemens Simatic S7-300,CPU 315-2 DP( 6ES7315-2AF03-0AB0 ).That is in the morning i dont know why but it...
3,372
This thread is reaction to another two: https://support.industry.siemens.com/tf/ww/en/posts/inout-parameter-problem/260345...
2,132
Dear All, I have a problem with the Simatic Timer. I'm writing a program to check the pulse signal input, if the input signal is keep changing...
2,846
Hello everyone , I have an engineering station with step7 program. I can make the modifications from this PC for 7 PLCs. But now I can not...
1,931
Hi Guys I Work in project using Wincc Comfort (wincc 7.0) and simatic manager I use siamatic simulator to test my work ,everything going ok but...
2,462
