a star delta ladder diagram
ladder diagram
N1(star)
i0.0 Q4.0
N2(Delta)
Q4.3 Q4.2
N3(timer S_ODTS to on the delta)after 5sncds will energize
Q4.0 T12 Q4.3
--[]--!S_ODTS !-----()--
!_______ !
Hope this will help u!
ladder diagram
N1(star)
i0.0 Q4.0
N2(Delta)
Q4.3 Q4.2
Q4.0 T12 Q4.3
--[]--! S_ODTS !-----()--
!________ !
Make sure u need to do the star/delta wiring as usual but to energize the relay is the output from the PLC..Ok!
Don't forget the mechanical interlocks -
Why bother with it anyway ?
Star Delta Ladder Diagram Example
Constructing a circuit for Star Delta control system with PLC ladder program is similar to wiring a physical relay controlled star delta system. The only difference when using a PLC is the absence of the physical relay control circuit which is constructed inside the PLC memory. You can find the details here: http://ijyam.blogspot.com/2013/04/electrical-wiring-diagram-star-delta.html
Welcome to the site.
You know that one of the biggest traps with this site is not checking the age of the post - we all still doit.
this post's from 2005 - so it might not need any further assistance
Here's a question I thought I'd never ask with all my 50 years of experience but I don't know - so I'm asking. I have to change a star delta...
23
3,159
Found that a trouble some pumps that kept causing overcurrent faults on the VFDs were wired in star instead of delta configuration. In star...
2,627
Hi all, Got a customer who's asked me to look at a new machine they've gotten in which they're having trouble starting. It's a brand new...
4,285
Without going into a lot of detail, 150 hp motor with a Star/Delta Start how much time on Star before switching to Delta. This is a compressor, I...
2,020
Hi. For a 100 hp (at 230 Vac) FLC is 248A (based on NEC table), is this correct: 1.) Branch circuit protection will be 248A x 250% = 620 A or...
2,608
