AB 1400 and Acromag 966EN-6006 modules
bazzab1
Dec 2004
WestOz
31
I am looking at this combo for a project where the client has specified the AB 1400 but also has 9 RTDs to monitor. As the RTDs would consume 3 slots in local I/O I was hoping to conserve slot space for digital I/O. I would use explicit messaging with Ethernet/IP to read the data with all the usual checks. Has anybody had any experience with the Acromag product ? Any thoughts on how else I can do this ?
34
I have a micro1400 processor running two routines (transfer compression/compression molding press). Recipe parameters are stored from job to job...
45
97
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
113
Hi, I am working with a Micrologix 1400 model 1766-L32BXB. With no input wires connected to the “in12” thru “in19”, I am getting 24 volts while...
224
