raccjim
I have a bit of a problem that I can't seem to find the answer to in my literature. I have an AB 1756-IFX0F2F Series A Analog Combination module with firmware Rev. 1.004. My problem is this: When a channel is configured for 0-5v., my overrange bit sets at 5.26 volts as it should. Yet if I configure a channel for 0-10 volts, the overrange will not set as designed when 10.5 v. or greater is applied. Any guidance would sure be appreciated!
