AB 1769-ASCII data exchange
MannyM
Oct 2008
JHB
70
I am using a AB CompactLogix 1769-ASCII module to read values from scales into the PLC buffers via the ASCII module word 8 to 107 (characters 0 to 199). The status bits of the input and output files per channel will be used to monitor the data Rx and Tx. Where can I find a sample program of achieving this in the user code or any suggestions on how to achieve this would be appreciated.
Where did you find the info?
I'm trying to use a 1769-ASCII with an L32E V16 but the manual is from 2005 and obsolete. Hopefully theres an updated manual.
NOTE: The manual shows to set the 1769-ASCII module up as a generic module and configure a bunch **** but the NEW rev16 and 17 firwares SHOW the 1769-ASCII as a module so all the Ethernet Ip like cryptic **** is no longer required.
It took me sometime to respond as we have been busy lately. Do research on any AB website on the module installed, in this case a 1769-ASCII connected to a L32E v.16 firmware processor. You should find an good example of doing the code, replacing some of the logic with your requirements and needs, as required.
so, Micrologix 1500. 1769-ASCii module. Bringing data in over the Channel 0 serial port. Setup is attached below. As is a snippet of the code...
1,644
Firstly some background: I have to add a 1769-ASCII module to an existing plc installation done by another company some years ago. The...
5,868
This is maddening. I'm developing a new application where a 1769-L32E with a 1769-ASCII module is communicating with a Tegam micro-ohmmeter...
1,594
I tried searching but either there aren't any answers out there for my Google-fu isn't up to snuff. My customer has a laptop with Labview set up...
1,560
Working with a customer who wants to do some ASCII handshaking between the PLC (a 1769-L24ER) and Labview on a laptop. I can send data from the...
1,872
