AB Basic Module 1746-BAS
jimtech67
Jun 2002
New Jersey
507
I need some help with AB Basic Module 1746-BAS. What is the designation of the bits of the first word of the modules input and output tables. The manuals do not list then. (or I can not find them). I only found the following.
I:e.0/13 = batter status
I:e.0/15 = run mode status
I am trying to trouble shoot someone else’s program. The seems to be a timing issue with slc500 and the device the Basic module is communicating with. I think some of the bits from the first word do not do what they are labels as.
First time using this Module Boy is it fun :(
GO JETS
Do you mean the serial port IO buffers?
I think you need to access those through Mfile transfers. It's been a while, though...
akreel I do not mean the M files I understand how they work. The M file are mapped to Basic module buffer words 100 – 163.
There are 8 words of I/O, 8 inputs and 8 outputs. These word are buffers 200 to 207 in the Basic Module.
The first word of each input and output have dedicated bit meanings. These are the designations I am looking for.
I think I see what you mean, and I understand your frustration with the documentation.
I haven't needed to access those words. I looked into it once, but never spent any time on it. Can you have your basic program write a value into one of those words and then look it up in the I/O table while you're online?
AK
Please I need to know how to add an image into a paper label, Im using a 1746-BAS module to send the data to a printer. thanks
1,834
Hi everyone.. I have 1 basic module SLC 500(1746 Bas), now i want to back up programmed (upload), but i dont know to cumunicate with this...
4,719
Hello, I am ver new to this AB basic module and currently seeking for some help. As a beginner, I used direct communication to the BAS port 2 to...
1,361
Hi everyone!:banghead: i Just wanted to know or to learn about Basic unit for slc500, can anyone here can give me a simple tips how to start or...
6,798
Hi all, Just have a quick question (might be a dumb one that I should know) about how to determine what the scan time is of the module. I don't...
3,943
