AB Controller Battery Status
Rizgar
Oct 2006
Erbil
Hello,
I need help to write code to get battery status of two AB controller (Logix5555 processor 1756-M14) ,which we use them in two different remote stations, on the program (RSView32) in Main station knowing that we use RSView32 and RSlogix 5000. These two remote stations have connection with the Main station (Logix5555 1756-M24) through SCADA.
You can use a GSV instruction on the Faultlog object, MinorFaultBits attribute. I can't remember which bit is the battery fdault but it'll be in the Help->Instruction Help->GSV->GSV Objects section. (No, I'm not a PC with RSLogix5000 installed!)
Use the following setup.
GSV
Class Name:FaultLog
AttributeName:MinorFaultBits
Destination:Minor_Fault
4=Instruction Execution Minor Fault
6=Watchdog Timer Minor Fault
9=Serial Port Minor Fault
10=PLC Low Battery Minor Fault
Thanks NOP, Bkottaras and Widelto for reply.
Widelto
I tryed to view sample code from ab samplecode site but I couldn't, I have ab site login user ID but I don't know what to write in the fields that needed to be filled in the samplecode request form can you help.
When should a new battery be added to the Micrologix 1500? Should I wait until the low battery light comes on? Or should I just add it now? Will...
2,764
Hello, fellow PLC enthusiasts, Iā€™m a newbie in PLC and am currently on a project that involves connecting an Omron CP1E (CP1W-CIF11) PLC to an...
47
Hello Folks, I have two watlow controllers that have two J-type thermocouples connected to two heating block on a sealing equipment. The...
65
Hi Everyone, I own a GE Versamax controller that I purchased for a class at Long Beach City College a couple of years ago. I lost the use of my...
345
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
255
