esandu
Guys,
It is about an AB ControlLogix 5555 processor communicating wth. a D-Net (Armor Block 1792D-8BVT8D) throgh a Flat Media Cable.
Some of the outputs on the armor block keep giving faults but still turning the loads ON and OFF. I replaced the block twice, made sure the addressing is correct and all the connections are OK.I've checked the loads and they are OK too.
Faults are on the output side and they come up even if NO LOAD is connected.
I plug in the inputs, then the D-Net cable and uip to this point it is OK.
When I plug in the Aux.Power cable some of the LED's on the output side turn red and flashing(usually 3 or 4 of them). I repeat, NO Load is still connected.
Network/Module LED Indicator is Flashing red.
I can see that with RSNetWorx, uploading the Armor Block immage.
At this time I have it running, with active faults but still turning the loads ON and OFF correctly.
Can anybody help me?
