AB DL40 replacment
Malcolmt
Dec 2010
Johannesburg
17
Hi All,
I HAVE to replace a bunch of DL40’s in my plant, it’s long overdue.
Rockwell doesn’t seem to have a small 4 line message display similar to the DL40. There are about a dozen DL40’s to replace.
My first question is..Does anyone know of an alternate product which can connect to PLC-5’s via RIO or Ethernet via a CL gateway ?
I have written a small app with VB6 to emulate a DL40 and connect to the PLC via RSLinx with DDE. It’s not the best way to go but my test app has worked faultlessly for a couple of months. I’m considering using a cheap panel PC with a VB6 or VB 2008 app.
Next question is... should I take the home brew app route, what would be the best product to connect to the PLC’s, like Kepware, Matrikon, etc and use OPC.
The last option could be a super cheap SCADA package to run on a cheap panel PC. All it would do is display 4x lines of text with a couple of variables embedded and use a large font similar to LED message displays. Does such a basic SCADA package exist ??
Malcolm Moorhouse
Johannesburg, South Africa
Hello everybody, I must upgrade a very old line by adding few new messages on three Dataliner DL40 Plus message displays. The bad part is that I...
6,546
Hi All First of all, I hope I'm in the correct place. I am trying to program an A.B DL40+ message display using the Dos based TI 505 software...
2,112
Hello, I want to send a countervalue to a DL40 textdisplay. This display receives a integer-word with is building as an Ascii. Example: If...
1,921
I have two old Allen Bradley 1746-A10 SER A chassis networked together and one of the chassis (master) is acting up on occation. I need to...
1,892
We have an A/B Dataliner DL30 that has bit the dust. It was connected to a Siemens S5 Plc output card. Is there any Quick replacements I Can...
3,485
