AB Micro 830 software
simisteven
Dec 2009
Mansfield
I have been playing around with this program. I have followed tutorial and create UDFB etc. However when I open program and select the named UDFB, it does not appear as per tutorial with and EN input and an OUT on the FB.
In fact it "steals" the first input as an enable and steals the first out put as an OUT.
I have attached a screen shot, hope it is clear.
I have managed to connect and download a simple program and it works OK however I cannot figure out how to monitor status of inputs etc.
I am used to S7 and this is a lot different.
Any help appreciated!
When you are deploying your udfb, check the bottom of the udfb window, you should see an enable EN/ENO check box...
Good Morning I have a new D830 micro panelmate for replace a broken one but i need micro panelmate configuration editor for paste the...
1,771
Hello friends We communicate between Micro 830 and a card that control DC motor via modbus RTU. We do not have any problems in communication. But...
1,525
Hi, Its possible communicate between kinco hmi (mt4404t) and Micro830 through a serial line ( rs232/485 ) ?
1,563
Customer has a Micro 830 (2080-LC30-16AWB) and a Panel View component C200 (2711C-K2M). They want to add remote connectivity. I was thinking of...
2,701
how do I make a timer timing bit in a micro 830 program using connected components?
1,602
