I'm installing a SCADA system that consist of reading data at a Wastewater Treatment Plant, Elevated water tank and 3 lift stations. My master site is the WWTP that we are using a AB Micro870 at that location. At the rest of the sites we are using AB Micro830 at the other 4 sites. For communication we are using Freewave FGR2 - 900Mhz radios and are using serial communication. The Master radio is located at the WWTP, at the Elevated tank is the repeater site with the 3 Lift Station radios as slave radios. The radios are existing radios, except for one, that a Freewave tech had me verify that they were working using Tool Suite and other than having to raise the antennas for signal strength, that was the only issue. We decided to stay with the Freewave radios to help the city save on cost!!!!
The problem that we are having is that we are getting data back from the slave radios and repeater site but the data is not correct and it keeps changing even though at this point we are forcing set inputs from each site. We have taken the master PLC and a lift station PLC and put a serial cable between each directly and used the "Receive/Transmit" wiring setup and are able to run our program with no problems. On the radios we have played with the Subnet settings outlined in the FGR2 manual setup but have had no luck. We have been talking with radio tech support but all we keep getting is to send an hour worth of data to them and wait about 2-3 hours before they call us back to change a setting but still nothing works. We believe that we are having a radio setup problem but cannot find it.
