AB powermonitor 3000 ethernet config
Mark@GBW
May 2017
Bjerringbro
Hi guys, may be an obvious answer to this question but I'm a total noob to AB powermonitors.
Our IT department wants us to change IP addresses across the plant to new ranges. On one machine we have a AB powermonitor 3000, which the PLC communicates with over Ethernet IP. The original manual is lost and the only document I can find online only states how to structure an IP address and warns not to duplicate other addresses, but not how to set/change an IP address.
I can find the device in RSLinx, but there's no option to configure module, and I can open the web-based program, but that appears to be read-only. How do I change the IP address of this device? Am I missing something obvious?
Sorry, I forgot to say, there is no display module. Only the unit itself. I'm hoping there's a way to plug in to the device to change the IP address as I currently can't see a way using RSLinx or via the PLC in Logix5000
We currently have an RSEnergyMetrix server in place that allows us to pull data from all of our PowerMonitor 3000s. We would like to pull this...
1,660
I am using a Allen Bradley Powermonitor 3000 on a DNET network and I require it to be Node 5, however when viewing it at the dispaly the address...
2,577
I have an existing power meter with 200:1 current clamps with 1.8 ohm burden resistors. I am replacing the meter with a Powermonitor 1000. Reading...
1,760
In search of single phase;phase monitor for 240v with modbus comms. Just need to monitor voltage and amps. Or I like to monitor voltage with a AB...
2,328
Hi, I have huge problem with sending data from PM500 to ML1100. I'm using rs485 connection with ml1100 as modbus master. When i try to read from...
2,139
