AB RSLogix 500 and 1768-hsc prog questions
Apr 2010
dayton
I am new to automation and new to the forum. I was wondering where I could find any sample programs for a Micrologix 1500 and 1746-hsc module. I will be using a BEI HS35 Incremental encoder with this. Also, how would I go about converting the encoder count value into degrees? Thank you for you time and help.
The 1746-HSC module is for the SLC-500 line. It is not appropriate for the MicroLogix 1500.
I don't think there is a 1768-HSC - thread title.
Do you possibly mean the 1769-HSC? The operating manual, 1769-UM006, has configuration examples.
You do know that the MicroLogix 1500 has a built in high speed counter?
Thank you theplcguy for your response. I am sorry the module is the 1769-HSC. I can not use the built-in high speed counter in the MicroLogix because all the inputs currently are being used. The current system has been in service for a couple of years. So to add an additional input card, rewire, and relabel would require more resources than just adding the 1769-HSC, encoder and encoder cable.
The SLC-500 'advanced configuration' takes some of the pain out of installing. Beyond that I can't help much as I've only used this in a Compact Logix system.
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
87
I have a little bit of experience with Allen-Bradley. I have a Micrologix 1500 (RSLogix 500) and a PanelView Plus 7 (FactoryTalk View Studio ME)...
170
buen dia. tengo una falla al pasar los tags de mi plc SLC 5 0/4 a mi panel me aparece un error Problem writing value " " to item <tag name>...
84
Will someone please convert this logic to pdf?
127
Hello, Haven't been on in a while. I need to generate a bit level pdf of the I/O for RSLogix 500. I can generate a report but it just shows the...
162
